- 11:37 AM
- Dec 29, 2015
- Strong Island NY
I'm trying to wrap my head around stratos. Just another part of the cycle to ponder and confuse me.Can someone clear my head? I've been staring at my 365xt with a degree wheel. I've heard raising exhaust and transfers is what they need, increasing strato duration, leave strato, gut strato. Intake, barely gets mentioned other than DO NOT go wider (no skirt).
In fully stock form, I'm at: Ex-99, Tr-116, In-74 and .030" squish.
I see I have 17* blowdown. If I raise exhaust I lose compression time on the upstroke right?
Where I get lost is if the strato ports are left operational, how can you increase duration on them? Seems to me that you could not exceed the intake duration, or better yet, they need to be the same.
One bullder here, well known to build some serious saws, says to "equal out the stratos"-make them open and close at the same times as the intake port(s). Until I have a strato jug in my hand, I won't understand this.
It does seem like the factory is giving you more tools to work with. More oil/fuel rich charge in the crankcase where the lubrication is needed and more transfer area.
My little brain tells me that strato saws should like less blowdown than a similarly designed non-strato dual/quad. They should have more transfer pressure with the first part of the charge being fresh air only. This would only be true if the stratos weren't "gutted". I assume that this means they are connected to the regular intake tract after the carb throttle plate and are filled with charge instead of just fresh air.
I've got a lot to learn here.
