rjames
The clean beaver gets the wood
- 7:47 PM
- Jan 11, 2016
- Michigan
Stihl MS460 ported by Randy Evans. Rebuilt with oem cylinder and meteor piston. Base cut, bridge ports, timing advance, muffler outlet opened up and dp cover.
Had 195psi after rebuild. Decomp just for looks, pops out right quick.
Has AM clutch cover, hd filter, outer dawg. Had to elongate the holes a bit to make the dawgs line up.
Runs out very strong, has maybe 10 tanks since build/port. Tunes easy and revs very fast. I always tune a little conservative just to be safe.
Only issues are oil tank flippy cap seeps a little when sitting, probably could use a new one. Has a small crack in carb box, can't see it, does not affect anything, just being honest. One muffler cover bolt is hex head, stripped one out and didn't have any torx screws.
Price? $600 + actual shipping pho. Let's not haggle that's a steal for a mastermind ported low hour saw. Not used nearly enough to have around and I have other needs right now.
