Hoggwood
- 8:35 AM
- Feb 6, 2016
- Above the 49th
Hey Cory, I recently picked up this 1631, my first of this series PM, I haven't done anything to it yet, not that it needs it, but was wondering if you know if when pulling the top end on this series saw, what is used to re-seal the cly/case halves together?, is it a sealer or a gasket?, my service book (intertec) only shows a gasket between the oil tank but doesn't state in the script or any pics what is used to seal the top and bottom cases together.Farting around with the 330 today. Took a couple of tanks to get it pulling OK. Wearing an old chipper and I could have taken some time to true up the rails. Still managed to fill the truck. More than adequately loud.
Hey Cory, I recently picked up this 1631, my first of this series PM, I haven't done anything to it yet, not that it needs it, but was wondering if you know if when pulling the top end on this series saw, what is used to re-seal the cly/case halves together?, is it a sealer or a gasket?, my service book (intertec) only shows a gasket between the oil tank but doesn't state in the script or any pics what is used to seal the top and bottom cases together.View attachment 161468
Thank you sir, yep, your IPL shows it much better than my old service manual, I've never seen any builds on this series of saw either.Nice. I never pulled mine apart aside from the usual consumables. Here are a couple picks from the IPL that came in a manual for the saw. Should probably take mine out for a cut again. It ran pretty well. Pretty loud.
Calls for a front and rear gasket between the halves.
View attachment 161643 View attachment 161644 View attachment 161645
Finally had a chance to play with this saw a little today, cleaning and resetting the points brought the ignition back to life, had it running without touching the carb at first, but it wouldn't hold the settings, so I pulled it and rebuilt it, running great, then no oil to the bar...lol....this version is manual only, oddly though there's a diaphragm using crankcase pulses that seams to do nothing on the manual oiler saws, luckily I didn't break it when removing the pump, cleaned out the housing and pump plus the check valves and now I finally have a complete fully functional saw, had a chance to put in wood and it surprised me, nothing spectacular, but worthy of holding it's own, over-all happy with it so far....Hey Cory, I recently picked up this 1631, my first of this series PM, I haven't done anything to it yet, not that it needs it, but was wondering if you know if when pulling the top end on this series saw, what is used to re-seal the cly/case halves together?, is it a sealer or a gasket?, my service book (intertec) only shows a gasket between the oil tank but doesn't state in the script or any pics what is used to seal the top and bottom cases together.View attachment 161468
That saws in great shape.I have one (a big thanks again to Pete), in the museum now.
Mark
Finished the 1629 today, cleaned up painted it a copper color instead of original gold. It's running very good.View attachment 221265 Working on a Skil 1629, it has spark, piston by exhaust port looks great.
Pulled carb and air filter assembly off, piston on intake side looks like new.
New carb kit, fuel line now waiting for a muffler.
