Piston diagnosis
Franksmallengine
OPE Member
12:29 AM
Usa
Recently got a husq 51 1998 model plan on restoring. The piston has disassembled its self and I am curious as to what happened so it doesn’t again. I have no knowledge as to its history when I got it it was locked up from piston skirt jammed in the crank and the smell of bad gas in the crank case was enough to over power the pb i used to free it up
Franksmallengine
OPE Member
12:29 AM
Usa
Entire saw covered in oil / dust mix as seen above had 1/2 inch in some spots
12:29 AM
I’d bet the intake skirt is much thinner than the ex side of those skirts.
The intake skirt is the thrust side of the piston. When it wears, it thins out and the piston starts to rock and slap in the bore. Then the skirt cracks, pieces come loose, and shrapnel goes round and round till everything else breaks too.
That’s my guess.
Lee H
9:29 PM
cape cod ma.
I'm with Al on that one. Looks like that piston has a lot of time on it and
had some serious piston slap.
BuckthornBonnie
12:29 AM
Penn Yan, NY
I’ve seen a 51/55? that ingested the choke plate.
It was still in the crankcase, though, and pretty obvious during tear down.
piston slap or ingestion of something… agreed.
kneedeepinsaws
10:29 PM
Oil Country
That’s my guess.
This is the main reason that pistons should be replaced in 2 strokes. The saying “ if it ain’t broke don’t fix it” does not apply here. Piston may look fine and have good compression but the skirt may be thin. Service manuals will specify the tolerances.
Another good reason to just pull the top end yearly and just check things out.
Franksmallengine
OPE Member
12:29 AM
Usa
Only thing I found was the crank seal spring missing (and bad gas) from the tear down i can say it had plenty hours but the ring and piston was perfect where it didn’t eat itself(even found crosshatch). My guess is it ate the spring and died the piston skirt was the same thickness from intake side to exhaust
Basher
1:29 AM
Canada
Are there any marks on the connecting rod, front or back side that would indicate the rod and piston skirt may have dinged each other?
