Lightning Performance
- 10:09 AM
- Jan 26, 2016
- East of Philly
I'm looking to build a 395 from parts. It will be a sawmill powerhead so broken cases, stripped holes, busted plastics and smashed rear handlebars don't matter. I can fix holes and cracks if needed.
Need to find two maybe three people to box up some parts they probably would toss and ship them here
Trades, dumb looks and paper is all I offer
Whole complete clean starter or I'll get aftermarket new. Rope and handle not needed.
OEM wrist pin bearing, wrist pin and clips.
Used top ends complete
Cases and case bolts, oil cap
Bar studs, outer bar plate and bar nuts
Tank handle, fuel cap, throttle cable
Oil pump, oil lines, washer and worm
X Handlebar screws for a full wrap
Xx Full wrap lower spacer
Top cover
AV mounts and screws
Clutch, drum, bearing, washer and clip.
Wiring and kill switch, maybe
Anything I'm missing?
Air shroud or conductor.
Decomp valve
Coil to fit the case
The flywheel will be changed.
Cylinders in OEM with stripped holes is ok with me.
I can get AM BB kits pretty reasonable but you can offer them.
Not interested in smeared or scored jugs with heavy transfer.
Top cover
Decomp valve
