- 2:23 AM
- Mar 1, 2016
- Mid-Georgia
Morning fellas...30 heading 68 and clear skies today.
Happy belated Birthday to the little one.Good morning men. Had a busy afternoon /evening with the daughters bday party
I assume this is the cylinder that you had cast Joe?Morning fellas
Made it home a few hours ago. Messed around in the shop for a bit.
Is everyone back to normal health at your place yet?Good morning men.
Squidward needs to patch his roofMorning fellas
After your findings a few days ago, did this make you snicker?Good Morning. Sunny 30°F/-1°C going up to 41°F/ 5°C. Daughter's house furnace failed again last night. Furnace guy needs to come back and check for this intermittent problem.
Had me scratching my head.Hoped he fixed it but that wasn't the case. Had many electronic snafus when working in a steel mill. Intermittent problems can be a nightmare.After your findings a few days ago, did this make you snicker?
If there's a relay coil somewhere on a circuit board that's where I'd look first. They vibrate and eventually works the solder joint loose. It'll be cracked /usually only visible on the backside.Had me scratching my head.Hoped he fixed it but that wasn't the case. Had many electronic snafus when working in a steel mill. Intermittent problems can be a nightmare.
