- 11:21 AM
- Jan 1, 2016
- Warren Center, PA
Sweet. Where's the pics dammit!Cylinder all turned, porting and polishing now.
That don't feel too bad after the first minute or so.when i went to chiropractor a few years ago i had to do shock treatment id have them turn it all the way up one on my neck the other on lower back
Not sure how much you're supposed to. I did It every time I switched sidesYeah that's not bad. Do you have to dress the wheel a lot?
Lmao that's pretty low voltage.when i went to chiropractor a few years ago i had to do shock treatment id have them turn it all the way up one on my neck the other on lower back
felt good huh? do it again.I got a real good one from a Chevy hei distributor. Hit my head on the hood, and then the ground lol.
negativefelt good huh? do it again.
That seems about right.Not sure how much you're supposed to. I did It every time I switched sides
depends on the wheel and the chain stihl chain is harder and wheel needs dressed more often some guys dress the wheel after 4 or 5 cutters and ive noticed the white wheel is softer than the salmon i dress when switching sides or if converting about halfway on a side on a 20 inch chainNot sure how much you're supposed to. I did It every time I switched sides
You will like it DJ. Dallas does a pretty good job, hit him up for a couple chains.I need to pick up a loop or two to try. Never cut with square ground.
im ok but no pee in the air.evening jake hows you did you lay down and pee in the air ?
Great pic Jake.that solar eclipse was cool it got dark as midnight today for about 2 minutes at 1:35 pm.
i took a picture through my phone using a welding helmet.
Good night DJ.I'm out fuggers... y'all have a good night!
