- 1:50 PM
- Sep 7, 2021
- S.E. Texas
Yes, having the correct tools makes a world of difference! I think the sleeve and the arbor were less than $30!
their bars are trash, unless they improved the last two years
I've seen fellow employees smoke a stihl bar in a month and a half. Anything can be conquered with brute force and ignorance.I've used the Raisman 20" bars w/o any issues, but when my Tree guy gave them a try, they did not last long.
IMO, a sharp chain goes a long way!
The bar I bought was for .058 chain and a .063 chain would have been sloppy and it was already started to delaminate before I even put it to use.
Maybe I was unlucky but I cant recommend that to anyone.
I just broke the pull starter plastic rope pulley on my Farmertech 880 . This thing is REALLY hard to start. Acts like a LOT of compression. So first question is why is it so hard to start. It will pop and snatch the rope out of your hand. The key and the key slot look fine. This is a new saw. Have only run it once for maybe 5 minutes. Second question should I put in a stihl factory starter. The compression release has been replace with a Stihl one.. Thanks for any help.
That's totally normal. Those big saws ain't joke. You might nee more "hand speed". Snatching the rope out of your hands means you didn't have enough speed to overcome the ignition advance and the saw kicked back.I just broke the pull starter plastic rope pulley on my Farmertech 880 . This thing is REALLY hard to start. Acts like a LOT of compression. So first question is why is it so hard to start. It will pop and snatch the rope out of your hand. The key and the key slot look fine. This is a new saw. Have only run it once for maybe 5 minutes. Second question should I put in a stihl factory starter. The compression release has been replace with a Stihl one.. Thanks for any help.
The D handle starter helps alot I think with the hard pullI just broke the pull starter plastic rope pulley on my Farmertech 880 . This thing is REALLY hard to start. Acts like a LOT of compression. So first question is why is it so hard to start. It will pop and snatch the rope out of your hand. The key and the key slot look fine. This is a new saw. Have only run it once for maybe 5 minutes. Second question should I put in a stihl factory starter. The compression release has been replace with a Stihl one.. Thanks for any help.
