- 8:02 PM
- Jan 8, 2016
- Farmington, CT
Point being order of assembly matters whether using my tools or not. Pulling or pushing a crank through a bearing and seal at the same time is asking for trouble. Worse...if you pop that spring out there's no way to tell until you do a vac test. If you pull the crankcase together...then install seals with that seal installer ...you can be assured to not pop that spring or damage the seals. Seems like nice peace of mind overall ...even if you have to sacrifice a set of pre installed seals.
