Armbru84
Just trying to get by
- 10:57 AM
- Jul 14, 2016
- Michigan
Saw started as a JMS saw. Was lucky enough that Al agreed to go through it. At the time he had to tig the flywheel side exhaust bolt hole and retap as it had been stripped. It has came loose once but it’s held fine for quite awhile now. Saw now has a 044 Zama carb. Choke setup isn’t as smooth as stock as it has an integral vstack setup but it works none the less.
not the prettiest saw but it runs very good. As you can see in the vid it pulled that 28” full comp in hardwood pretty good. That was before the vstack setup and it has picked up since then. Comes with all the extra filters and stuff you see in the pics. Will
Come with a 7 or 8 pin depending on what the buyer wants.
$475 and the ride. PayPal F&F or add 4%.
Any question...let me know.
