- 7:47 PM
- Jul 22, 2017
- San Antonio, TX
Ok, those of you who collect Jonsereds know these are rare as rocking horse poo. After years of looking, I've only seen 4 or 5 posted online. I'm sure there are more out there, but you'd definitely be the only one on your block with one.
The 110 is the predecessor to the 111, which was followed by the 111S. As best as I can tell, the 110 was a one year only saw, produced in 1972. It was followed by the 111 in 1973, and the 111S came out in 1974. It's different than the 111S in a few different respects -- it has needle crank bearings, not roller bearings, and the OD is a good bit smaller, so the cases are different. The oiler has a slightly different configuration, the decomp is different, ignition configured differently, and the 110 has a poly flywheel instead of aluminum.
I found this particular saw in Sweden years ago, and finally got around to giving it the full rebuild that it deserves. Although I had nicer components to put on it, I went with all original items (all exterior parts, jug, piston, etc) with one exception -- a top cover from another saw. The original, which will be included as well, has a few broken mounting tabs.
Anyway, I split the case, installed new crank seals, gave it a thorough cleaning and inspection, rebuilt the carburetor, went through the ignition, opened up the fuel and oil tank and cleaned it out, giving the fuel tank a coat of Red-Kote to seal it up good. The saw is in very good condition, muffler is un-dented and solid, no broken tabs on the top cover, no stripped bolt holes anywhere, compression is great at 193 psi(!), and it comes with your choice of bars - a 36" Jonsereds hard nose or a 36" Oregon roller tip. It's set up to run 3/8 chain, and has a rim drive sprocket.
It starts easily, revs great, idles at 2,200 and tops out at 11,500 at WOT, unloaded, four stroking. Will clean up in the cut.
I am in San Antonio, Texas but I will ship worldwide. I will also consider trades for the following: Jonsereds XA diesel, Stihl Contra G or GS, or Solo Twin. Trades of other saws (Stihl 090, 090G?) + cash considered, too.
Hard to put a value on these. I'd like to get $2,500 for it, but the price is negotiable.
