quattro90
- 9:19 PM
- Jul 23, 2017
- Central Indiana
2013 Jonsered 2166 xt with extremely low hours that was converted to a 75cc OEM BB using an Husqvarna XPW P&C non-xt 51.4mm by AWOL. That includes the machining of the squish band and cylinder. This saw was setup for work and is extremely strong and torquey. Tillotson HS296A carb with 17.5mm venturi and other 385/390xp intake parts were used in conjunction with an SEM unlimited (black) coil. This redhead also is wearing a MG muffler with the nicest brazing work I've ever seen. This saw has only 4-5 tanks, and the rings aren't even fully set yet and it's still blowing 180PSI+ cold. 7 pin sprocket 3/8 .050 was run all the way up to 32" skip tooth. The only noticeable cosmetic blemish is from shipping. The lowest fin on the cylinder (clutch side above the external transfer tunnel) is chipped off, as you know this doesn't affect performance at all. $975 shipped here in the continental US, unless you live in PST just contact me for a shipping quote. Any questions just ask.
