Johnmn
- 7:16 PM
- Feb 18, 2016
- Minnesota
Jonsered 2150, this was going to be my 346 conversion but oh well. 45mm top end, I put a good used low hour OEM flat top 2152 piston in it. I swapped out the coarse thread bearing cut for a fine thread, filed a slot for the future 346 impulse. Base gasket delete, timing advance, muffler mod, new fuel filter, swapped out the spur drum for a spline set up with .325. New OEM muffler support and a little heat tape on the case under the muffler. All ready for your 346 p&c or just run it as it is.
$225 shipped lower 48 friends and family
