Is Husqvarna and Stihl chain compatible?
5:50 PM
Just a quick question, but I have a Husqvarna chain (16" .325 .050 66dl), and was wondering if it was compatible with a Stihl chain (16" .325 .050 67dl)?
Can I use these chains with any 16" bar? Are they interchangeable?
Thanks in advance for your help.
5:50 PM
Ok. Thanks. Just curious why one was 66dl and one was 67dl. Both 16" .325. .050.
rburg
4:50 PM
Tennessee
Several Stihl mount bars use different length chains than Husky mount bars do.
5:50 PM
Ok. I guess I just gotta try it and see.
johnny5ny
5:50 PM
Saratoga Springs NY
There's a good thread on this exact subject over at chainsawrepair. Gimme a sec and I'll try to find it....
5:50 PM
jakethesnake
I Am The Snake
5:50 PM
Here & Now
Likely won't fit one driver on 16 inch prolly be too loose or too right Try it as long as you can make it tighten up proper than it'll work. Chain is chain but that small difference may screw it up. It may work on one or the other
Philbert
Chainsaw Enthusiast
4:50 PM
East Dakota
I have a Husqvarna chain (16" .325 .050 66dl), and was wondering if it was compatible with a Stihl chain (16" .325 .050 67dl)? Can I use these chains with any 16" bar?
The 16" part is practically meaningless. Any bar between 15 and 17 inches (front of powerhead to tip of bar) will be called "16-inches". That's why we count drive links.
I had 2 STIHL saws, that used the exact same chain (0.325 pitch, 0.063 gauge), that each had a '16-inch' STIHL brand OEM bar, that used totally different drive link counts. The MS250 used 62 drive links, and the MS260 used 67 drive links. But if the pitch, gauge, and drive link count are the same, you can run any brand of chain, just like you can mount any brand of tire on your car if the numbers on the sidewalls are the same.
Sometimes a one drive link difference can be taken up with the tension adjuster. Sometimes it can't. Some companies will have weird drive link counts just so you go back to them to buy new chains. For example 56 DL is one of the most commonly available 3/8 low profile chains. Many ECHO saws require 57 DL.
It is possible to add or remove links if the chain is in good shape otherwise - a good chainsaw dealer can do that for you for a few bucks.
Philbert
CrystalRiver1
4:50 PM
Alabama
BTW...any compatible Husky chain for my Sthil MS 261?
Currently running Stihl OEM 18" Saw Chain Full Chisel .325" .063" 74 DL 26RS-74
