I have to ask what the Gadgeit is under the saw like a clamp or perch??The 621 was also equipped for the brake/kill switch, I've never seen one set up that way but you can see how the parts fit to the saw. That hard rubber block filled the space.
Mark
Hard to see the notches Thanks for the explanation Congratulations on keeping track of tool for 35 plus years I misplaced my scrench for my 056 magnum within weeks back in the 80'sThat tool was supplied with the new 621 I bought in 1981, it locks the clutch in place so you can remove the nut and change sprockets. As you can see, the clutch drum has a couple of notches that the tool fits through to engage the clutch and hooks on the bottom to keep the crankshaft from turning.
Mark
Mark
