quattro90
- 5:15 PM
- Jul 23, 2017
- Central Indiana
Husqvarna 545 fully rebuilt from the crank up with all NEW OEM parts. Cylinder, piston, ring, bearings, seals, case gaskets, lines, filters, clutch drum, oil worm gear, .325/7T sprocket, spark plug, etc. Pressure and vac tested 100% using OEM Husqvarna block-off plates. I have video of it cutting after full AT reset if you have an iPhone or WhatsApp just PM for video. Custom base gasket was made to set squish at exactly .020 with a stock appearing muffler mod and plugged decomp. This thing screams! Starts right up and is ready to attack your firewood needs!
