t4driller
Daddy Day Care
- 10:42 AM
- Feb 23, 2016
- Southwest pa
Have a nice 346 for sale. Built on a 353 case because the case it was on has a broken spot where the screw for av buffer under clutch cover goes. Chunk missing. So i put it on a 353 case. Another problem i found was someone put a 44mm piston in a 44.3mm cylinder. So i through a new 44.3mm oem kit on it. Also has new top cover, clutch cover, bar plate, and fuel line. Metal intake clamp was installed. Only thing that isn't oem is the metal intake clamp. All stock $380 ps or could be ported. Thanks
