- 7:17 AM
- Feb 9, 2019
- New Jersey
Have a trio of saws that are taking up space and decided it is time for them to go.
The first is a husky 445 that I bought for my father at tractor supply. This saw was on the returns rack with a toasted bar and chain with creosote all over it, otherwise looked clean. Can not believe they took it back. I also noticed when I pulled the muffler for a piston picture that someone has ground (not very well) on the muffler inlet to match it to the exhaust port. Saw has prob had less than 10 tanks thru it. I ran it about 2 years ago after my father passed away and it ran good, but signs of carb issues near the end of the tank. A carb kit and fuel lines and that saw should be good to go.
Second is a husky 455 looks low use that has a broken handle where someone got it pinched. Also was missing the screw to the choke lever. I did run this saw about 4 years ago and it ran great but prob needs a carb kit and lines now.
The last is an ms210 that fires with gas down the carb, had good compression but starter rope broke and saw has sat waiting to be fixed.
I will never get around to fixing these so they need to go. Is $100 for all of em fair? If not make me an offer, Thanks!
