SOLD Husky 288 365-72
cabbageroll
2:56 AM
B.C
Next on the spring clean
Saws a 181 bottom with 288 top end ran after the swap now think the fuel lines bad?
Extras
181 top end that was removed in good shape
2 wraps handles and a half I believe if for them
Low top and high top cover
Extra high top filter elbow
Starter cover works/pto cover needs band
Extra muffler
288 bottom end- good just has minor cracked case with coil, pump flywheel
Extra any other 288 misc I find in my clean up
$300 usd
060CEB4D-C6FA-4D40-BB70-3674D981C7BE.jpeg 2FDB5F4A-6303-4E8C-9461-0200169D44BF.jpeg
365-72 bits
Case half
372One jug with plate wear
2x 372 jugs with transfer that “may” clean up
Couple flywheels and a shroud
372 New meteor piston and rings
Red tank missing levers etc crack at the back where handle joins doesn’t effect gas storing ability
Walbro carb missing caps
Couple carb boots
Aftermarket hand guard
Carb base plate missing carb rubber mount.
All the little misc I find while cleaning up
In my clean up I’ve put together a bag of misc screws that should have you covered except the smaller hand guard screw and carb bolts.
$100USD?
3678BC58-3665-4405-854B-26230993DEC4.jpeg 08E38ECC-5CE5-4214-9CE8-2583532AB66B.jpeg
Not selling pieces
All items +shipping from Canada-
Pay pal ff or add the fees
msellers
2:56 AM
Nevada
Sending pm on 288 stuff. Shipping will be a decision factor.
quattro.pilot
3:56 AM
Leduc, AB
Which model is the case tag for in the 3-series lot? Figure you have more goodies hiding that you have spring cleaned yet? Cheers, thanks -Rob
cabbageroll
2:56 AM
B.C
$100 for 372/365 misc bits, send me a pm pretty keen to offload save it from the dump.
