OnTheRoad
- 5:05 AM
- Nov 24, 2019
- Kansas City (not Kansas)
I'm playing with a 350 husky with maybe a few tanks through it that will not start. It won't hit a lick no matter what I do.
Piston and cylinder are perfect and compression is very strong though I can't find my tester. I did find my leakdown tester.
Air, fuel, spark, compression.
The plug fires readily and I set the coil gap with a business card.
Fuel is fresh truefuel.
The plug is dripping in raw fuel after fewer than 10 pulls and the muffler is full of fuel. I've tried the needles all the way in, one turn out, etc and with the plug out and the throttle in the operating idle position it's blowing fuel mist out the plug hole. In fact blowing drops of fuel out of the plug hole. The only way it doesn't blow drops is when the throttle is WFO.
Obviously it's way rich, too rich to fire. No amount of carb adjustments affects this.
Plug still fires so I don't see how a new plug would help. Carb must be the issue, but why?
