Here comes Jonny!
Wagnerwerks
9:09 AM
Pa
Ok... So I'm back..
Here's the hlsupply haul. I got a 268 piston on and checked squish the cheating way with just one long piece of solder through the plug hole. It hits with one base gasket, but with 2 it's fine. Squish with 2 is a nice .019". Each gasket measures .016 so that was simple. :)
Wagnerwerks
9:09 AM
Pa
And here's a 268 slug. Do I need to source a different bearing? Anyone have a 268-272 bearing they can measure? 20171202_184745.jpg
Wagnerwerks
9:09 AM
Pa
1512269669899-156088668.jpg Okay so I actually have a bearing that takes up the slack in the piston pin. I did come up with one Oddity. One of the two Pistons that I got for my Black Friday deal has the pin drilled crooked. I thought it was just my eyes or maybe an odd casting but after measuring it's about 1.5mm off. Think it will be ok?
RIDE-RED 350r
9:09 AM
Blossvale NY
I would not use it myself. May be nothing to worry about but I wouldn't chance it
Wagnerwerks
9:09 AM
Pa
Stock bearing...
Bearing I found in my box... I wish I knew what it was from....
Wagnerwerks
9:09 AM
Pa
Kinda what I was thinking. I hate to complain about it but I may have to give them a call. Hls is truly one of the best businesses I've ever had to call up though so I'm sure it will be fine.
Wagnerwerks
9:09 AM
Pa
Since its drilled off center won't it try to rock the piston?
I think it might but it's actually like the skirt will be turned a bit. Not a big deal till I put a new piston in it someday and the ports are off. Lol.
RIDE-RED 350r
9:09 AM
Blossvale NY
I'm sure they will take care of you and I think you would be wise to not run it. I can't imagine anything good happening with that wristpin offset like that
RIDE-RED 350r
9:09 AM
Blossvale NY
Wait a sec, both sides are not offset? Can the pin even be installed?? I'm thinking not if the other side is centered
Wagnerwerks
9:09 AM
Pa
Clutch bearing perhaps??
Maybe... Not sure. It is in very good shape for that as it is used. It's a rediculously small amount too wide. I'm thinking a single stroke of a file on each side of the inside of the piston and it's perfect.
Wagnerwerks
9:09 AM
Pa
Pin fits right in. It's like it was rotated a tiny bit too far when drilled and the piston skirt sits to one side of the port a little over 1mm more than the other side.
I got two. One for me and one for my buddy. The other is spot on and if I didn't have it, I'd have thought this one was normal.
