- 12:00 PM
- Dec 29, 2015
- Strong Island NY
Great stuff guys.
I'd like a piston with higher compression height.
A lot of Metallurgy involved. A lot of machining too. Aluminum is hardened before use. Welding makes it soft again.
I thought about building up the entire crown. That may work.
Looks like the 111 piston is flat, 026 is domed.The other 44mm piston of note is the Dolmar 111
The Meteor catalogue lists them as having identical specs so I wonder why they list them as different pistons?
Curious!
Be interesting to see piston pin to crown height. I may have a 111 in my pile of saws and parts I got a few weeks ago. I'll go take a look...Looking at it, the Dolmar 111 piston, if it does actually have a flat top, is looking like a good starting point for a basic flat top machine job
You are correct. I popped the top and its 44.8mm and single ring54cc... will be a bit bigger I think
Single ring though
How big is the Pin?You are correct. I popped the top and its 44.8mm and single ring
Pretty sure that will use a bigger wrist pin. Wouldn't bet my life on it but I recall them being larger than a saw by a good margin.Could be worth a phone call for more information?
http://www.wiseco.com/ProductDetail.aspx?ItemID=648M04400&ModelID=242&ModelYear=1985&AppID=3121
