gurwald
- 12:53 AM
- May 7, 2019
- Sweden
Had this clone 200t I put together almost two years ago it started acting up, air leak symptoms.
I found a cracked fuel hose so I changed that.
But it was still acting like it was sucking air, I found I would kill it spraying break cleaner under the flywheel.
So I tore it down today, the seal on the flywheel side was too far in , my fault. Was rubbing against the bearing.
I noticed a significant play in the crank bearings just not sure if it is a problem or not it has these rollerbearings without inner races.
I filmed but did not upload to youtube yet...
Anyone with experience of these saws know if some play is ok or not?
Its a good saw, when it runs...
