Terry Syd
- 11:40 PM
- Jan 18, 2016
- Comboyne, NSW Australia
I decided to start this thread because of a 357 Randy was running that became 'heat soaked'. The power dropped right off, as it usually does when a two-stroke becomes hot. In fact, the difference on a dyno between a 'flash' reading when cold and a hot engine can be a 20% difference in power. That 20% power drop doesn't occur all at once, the power drops off as the engine heat increases. If we limit the maximum heat or even just slow the heat rise we may pick up some useful power.
Two-strokes are to a large degree 'liquid cooled' - the liquid being used is fuel. The extra fuel absorbs heat when it is vaporized. Different fuels have different latent heat of vaporization levels. When using alcohol, the extra fuel and its latent heat of vaporization can give a stock engine another 6% power (increase the compression to take advantage of the increase in octane and you can get a lot more).
However, dumping lots of extra fuel through an engine has its limits, plus it wastes extra fuel.
A chainsaw is an AIR cooled engine. - Even a water-cooled engine is cooled by air through the radiator. The radiator is INCREASING the SURFACE AREA to release the heat and a FAN increases the air flow through the radiator.
Increasing the surface area can only be done to a limited degree on chainsaws, however removing obstructions on the cylinder can increase the area that the air can flow through. Removing casting flash and portions of the cylinder that were necessary for the casting process (but not for operation) can increase the area available to the air flow.
Air flowing onto a cylinder must also flow away from the cylinder in order to have a good air flow. It is not uncommon to find objects on motorcycles that are placed directly behind the cylinder. If the air can't flow away from the cylinder, it is not going to have good air flow across the cylinder.
On all the Huskys that I've modded I block off the 'air injection' system. To make more power, you have to burn more air. That air is sucked in through the air injection system - which comes off the FAN ON THE FLYWHEEL. The more air I burn, the less air I have to flow across the fins. - It is a COMPOUNDING problem the more you mod such an engine, the more heat it produces and the less air you have to cool it.
There is also the issue of engine longevity. Perhaps it never gets hot enough to seize, but a more stable running temperature will give a more stable expansion of the components. If the components are constantly changing tolerances, there will be more wear.
What I'd like to see is some objective evidence of how much extra power, if any, blocking off the air injection system creates. If an engine can loose up to 20%, what if a simple modification could reduce that to 15% - that could be a neat boost in power with minimum effort and probably result in less wear in the engine.
