Echo mount bars
whitesnake
11:14 AM
NY
Have a new CS490 that I haven't even run yet. Just happened to get a decent deal and always wanted to try a 490/500/501...along with a 590/600/620? So...problem is what bars fit them? It came with 20" .325 which like I said I haven't tried...but seems like it would dog pretty good. I know it's a weaker 50cc and that's a lot of bar. Is there options for aftermarket bars in the 16-18" range? Total, tsumara, sugi, etc? I know some can be made to work on certain saws such as the total I have on my dolly 421 .325 conversion. So just curious what's out there. Thanks.
11:14 AM
I'm running a husky small mount 18" on mine
.325 .50 72dl if memory serves.
It's a little loose not much.
11:14 AM
The 590 i used d009 and cut the chains down one or two link's.
Same deal a little loose but worked great.
AVB
10:14 AM
Elora, TN
The CS490 uses the Oregon K216 mount.
180VXLGK216 Bar, 18" VersaCut™ 72 .325" .050 7
188SLGK216 Pro-Lite® Bars 72 .325" .058 7
180MGGK216 Pro-Lite® with Guard Mate® Holes 72 .325" .050 7
180MPGK216 Pro-Lite® Bar 72 .325" .050 7
180GLGK216 PRO-LITE® Bars 72 .325" .050 7
AVB
10:14 AM
Elora, TN
From what I have read you also need to add an oil feed hole to the K095. But yes it will work with mods.
whitesnake
11:14 AM
NY
So K095 seems to be the go to? Modifications to adjuster and oil holes? What lengths are you guys pulling with these?
10:14 AM
I'd keep what ya got for reach and stuff.
10:14 AM
I'm cornfuzed if your using say a 20 D009 on a D176 saw wouldn't your DL stay at 72?
11:14 AM
Running a 18" gb i didn't have to change anything
Bar's from different makes may need some fitment.
00wyk
4:14 PM
Ireland
On small saws, the K095 is like o-negative blood. It's the universal donor. A mild amount of massaging and you can make them fit about anything.
LouCi4er
6:14 PM
Greece
Echo cs 590 uses the d176 bar mount,same as older Poulans.Echo cs 490 uses the K216 bar mount as already mentioned.K095 bars(husky small mount) can be easily fitted with minnor mods but K041 bars is a direct bold on without any mods.Only problem (for me at least) is that i can't find any K041 .325 058 bars.050 k041 bars are out there.
Fisrt post here,great forum.
Woodpecker
Sassy Madam
11:14 AM
Nice first post and welcome to the jungle. I ran into the same thing with k041 when I was searching for a Total L&T for my cs501. I ended up just going with the husky small mount k095. 5 minutes with a grinder and go cut wood. Pretty easy mod really.
