Deane
New OPE Member
- 4:30 AM
- Dec 30, 2016
- Farmington, CT, USA
I am trying to fix an Echo PB-250LN hand-held 2 stroke leaf blower for a freind. It had no spark so I narrowed it down to a bad coil. The coil part number is listed as A411000501. Found a used coil that looks identical except the outside plastic is dark blue instead of grey. It is made by the same company, Oppama, (stamped C11907) but the part number is slightly different, ending in 251 instead of 501. I installed it and now I have spark as demonstrated by removing the plug and placing against the block and pulling the starter. When the plug is re-installed it refuses to fire... even when using starting fluid sprayed into the carb or the cylinder! I have never seen an engine that would not even pop when this is done. Anyone have another idea about what might be wrong? Thanks.
