Duke Thieroff
Fill your hands you SOB!
- 7:22 AM
- Jan 2, 2019
- Beaver County, PA
This is a tale of 2 saws here, each with it's unique things.
$550+ the ride for the whole works...
We get pretty darn cheap commercial rates so it would probably be pretty reasonable.
First off, they both start up and run pretty good. I haven't vac/pressure tested them. They both seem to run fine and weren't exhibiting any issues when running. Both have good bottom ends.
Saw #1
Was scored, had fuel line issues
I believe I ran the carb through the USC, diaphragms were decent
-Had a really nice Gilardoni cylinder at hand, replaced with moly coated piston.
-Cylinder cover screw has damaged upper threads, put in a slightly longer screw, holds fine.
-Drilled and retapped rear left cover stud, original was broken
-New fuel, impulse, return lines
-Needs new rim
-New aftermarket air filter
-Some general cleaning
I think that's it with that one....
Any questions please ask.
Saw #1
-Needs new rim
