Jimmy in NC
- 5:41 AM
- Dec 23, 2015
- North Carolina
OK you are a day late. I'm sure I'll manage to get it back together JJ.. anything else before I split it? May occur tonight if this 441C will get off the bench.If you can avoid it, try not to take the brake system completely apart- it can be quite painful to get it all back together (there may be a servicing tool that makes the job much easier). Years ago, I did full side-by-side rebuilds on both a 9000 and a 9010, and the brake systems were the most difficult part. The oil pumps usually need going through as well but there is an oil pump rebuild kit available that contains the pump piston and all the fines.
