Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
11:15 PM
Ok so here’s a rough guideline how to rebuild your oil pump on the 7900 series saws... First you will need this kit. 792D4E16-60E5-4F11-9F8C-A035B152D3C5.jpeg You will need a punch or the right size drill bit to tap out the roll pin. I ground this one down to fit. DE243D97-9B8B-4A12-886D-9A79FB494D24.jpeg Next unscrew the white plug from the end of the pump and the guts will come out. Then tap out the roll pin with the pump secured in a vise. Then the adjustment screw can be removed.DB497177-BA6B-418F-AF00-62C23E3BF317.jpeg 7429DA1D-73E4-49CE-973F-DF3E5B8A7A4C.jpegNotice the worn nub on the screw? That’s why this saw wasn’t oiling good anymore. There is a oring on the screw and spring. Put that oring and spring on the new screw. Align the screw properly in the pump, push on it and get the pin started in there. Make sure the screw is seated in properly before you drive in the pin. Reassemble the pump and prime it with oil by filling it and turning the drive wheel. 8ACB19DA-504B-4EE1-90E5-D670DF767F85.jpeg
11:15 PM
Cool. You didn't file or grind down the pump pin to make it oil a bit more? Do the pump mod instead of pump rebuild?
How much are those kits?
No oiler mod needed with a 64cc. They will oil a 32” .063 bar ok with the 64cc cylinder. The 7900 is sort of stingy (not near as bad as 1128 series stihls though) with a long bar with the same pump because it has more chainspeed/more rpm in the cut = more friction. It also burns more fuel so the gas to oil usage is not 1/1 like the 64cc. Pump needed a rebuild because the plastic “nub” was worn out on the adjuster. Rebuild kit is cheap. 6A85D882-1B7B-48A3-8B18-71E45E5B184F.png
11:15 PM
I can see the difference now that I put them side by side.
I have a rebuild kit, but hopefully it doesn’t have to be rebuilt for awhile anyways.
It should last you a long time, this one was a higher hour 7300 chassis that was scored then a 64cc cylinder fitted.
11:15 PM
Ok guys so the saw runs nicely, first time out it wouldn’t oil properly so I took the pump off and rebuilt a different spare one I had. Oils great now. Must’ve messed something up or the pump body was just bad. I did notice it’s crucial to line up the adjustment screw in the right position and push it in. This prevents damaging it when installing the roll pin.
11:15 PM
The flesh colored safety chaps were cool, they a special order?:rolleyes:
I don’t recommend doing what I do lol. I always wear some sort of ppe logging. Always wear steel/composite toe boots too. Not usually cutting cookies, I should. I just relaxed my standards.
