- 3:21 AM
- Dec 31, 2015
- East Jordan, MI
And the exhaust port on a 7910 can be made a whole helluva lot bigger...7900 is windowed
7910 is slab sided
...if yer into that
7910 is slab sided
...if yer into that
But they can all be made to perform the same with mods.
Told yaCheck the videos I just posted earlier. There is little to no difference in cutting speed between the two models.
My unofficial timing says the Makita EA7900 (PS-7910) was actually a tenth faster in the cut. Same bar and chain.
I ended up buying a cheap AM top end from HL Supply on a black Friday deal. The saw I have is a basket case and I didnt spend much money. I wanted to try my hand at porting so I figured why not try on the 7900 with a cheap AM top end... I haven't done anything with it yet. I probably need to acquire a gasket kit and bearings also.Stock against stock the true and original "7900" will take the cake and walk away from her successor the "7910" - that is my best guess.
Modified, depends on the level of mods, skills of the individual modifying the saws, which direction the mods are aimed torque or rpm.
During this discussion You may have missed it , but @SOS Ridgerider just posted that he got an OEM "7900" cylinder (left hand DeCo, non SLR outlet) featuring a side slabed piston.
That should tickle some of You guys.
@Marshy did You get Yourself one of these for Your saw? I know You asked for one a while back.
Steve, I watched your video and I'm still in the dark.
My conclusion - you film other's much better than you take selfies!!!
Damn!Will have a sale on Makita EA7900 GTG weekend. $655.20 PHO. $699 with 20" bar and chain.
Those were used on late model PS-7900s sold in other parts of the world. There was a batch of those imported here that got kicked out by the Epa.Got this little guy in the mail the other day. OEM, and what looks like manufacture date of 2012.
Edit: Take a look at the cylinder and the piston. 7900 cylinder with 7910 piston.
View attachment 177036 View attachment 177037 View attachment 177038
They’re still available. I just ordered another one now.Those were used on late model PS-7900s sold in other parts of the world. There was a batch of those imported that got kicked out by the Epa.
