Crank flywheel side thread save.
srcarr52
2:28 AM
Iowa City
Someone sent me a 395 crank with no threads left on the flywheel side. I worked a little magic with the tig welder and lathe to make the threads reappear.
8:28 AM
Looks good.
Are You going to heat treat the threaded end or leave as is?
2:28 AM
Wow! Awesome job there Sir!
srcarr52
2:28 AM
Iowa City
Looks good.
Just leave them as is and be easy on them. It's ER70S-2 filler so it's not really heat treatable. I think the original threads may be rolled in after heat treat which are very strong.
Armbru84
Just trying to get by
2:28 AM
Michigan
All my experience with thread rolling is in the green state...I don’t think you can thread roll steel that’s been heat treated.
srcarr52
2:28 AM
Iowa City
Very common to do on bolts and studs with low stress ratios. The residual compressive stresses at the thread root are extremely beneficial for fatigue life because it delays crack initiation. Heat treatment after rolling removes the stresses and the benefit.
Armbru84
2:28 AM
Michigan
Gotcha. Guess I was more thinking of spline rolling. Didn’t really consider those other applications.
stihl_head1982
Here long time
2:28 AM
USA
Your education is showing again sir. Nice looking save too by the way!
srcarr52
2:28 AM
Iowa City
srcarr52
2:28 AM
Iowa City
I buggered some crank threads on the FW side over the winter.
I found a company that makes split dies.
They work awesome!
I should have taken a before picture... there was no threads to save.
In a pinch I've made split dies but cutting a nut in half, putting a score in the 1/2's and using a adjustable wrench to back it off.
