SimonHS
- 3:15 PM
- Nov 4, 2020
- Yorkshire, England
I understand the terminology and how it should work!
But, the rivet is thicker in its mid section (where it holds the drive link) - it technically can not be punched out without bending the opposite side tie strap!
Also, how exactly is the anvil supporting and holding the chain level - I looked at it and the rivet doesn't seem to be at the exact same axis as the punch and therefore gets pushed out "crooked"?!
As I said, it all looks weird to me and my breaker & spinner have been collecting dust from day 1 since I purchased them.
The breaker I purchased came with bent OEM punches and a couple chain sections with FAILED breaking attempts.
The previous owner must have tried resizing his own chains and failed.
I made a couple custom punches (some of which with "replaceable" tips) but have yet to give breaking & spinning a try.
I'll get to it, You'll be the first I will turn to for help!
Sometimes it helps to grind the top of the rivet before punching it out, to weaken it.
This video shows a good view of the process.
