Philbert
Chainsaw Enthusiast
- 4:22 AM
- Jan 30, 2016
- East Dakota
How does it look with a chain?Saw these mentioned in a thread a while back, and bought one to try. Anybody use one?
Shown here: 12" Cannon Pruner Bar alongside the 10" OEM guide bar from an Oregon 40V pole saw.View attachment 88739
Philbert
Photo?I have a Solo pole saw which has the same head as Efco which is articulated allowing a range of adjustment.
How do you like that polesaw?
I have one for my Stihl but haven't gotten around to using it yet.Saw these mentioned in a thread a while back, and bought one to try. Anybody use one?
Philbert
The pinching issues would still be the same, but at least you are standing at an angle to the branch rather than under it and so your vision of the cut may be improved. Certainly safety would be a benefit.I suppose that the bar would still pinch if the branch twisted on the way down.
Trees are good with surprises like that!
Philbert
We have a couple in stock
I had to modify mine to fit my Stihl. Though all that was needed was to cut the back out of the studs slot.* UPDATE *
As noted, I bought this angled bar to use with some of the powered pole pruners ('PPP'!) I use, and happy to find that the same mount fit my personal powered pole pruners ('PPPP'!) - 40V Oregon, battery-powered models, as well as the STIHL HT131/133 models that I sometimes use.
Heartbreaking to find that although the bar fit the mounting slot, adjusting holes, and oiling holes for the Oregon products, the angled design did not clear the covers, and would not work without significant modification to the pole pruners.
It did appear to fit the STIHL models when test fit at my local dealer.
So, I still like the idea of this bar, but want to caution purchasers to verify the fit with their pole saw, and not just the mount pattern, unless they are willing to modify the saw head.
If Cannon would make a full-size template of the bar available (via PDF download), it would save some time andreturns, even if they have not test fit the bars on every pole saw on the market.
Philbert
What also gets me about most pole pruners is that they use narrow gauge .043" bars and chains . . . it does allow Stihl dealers to ask about $25 for one chain to fit a 10" bar.
Here those .043" chains cost about 18 dollars and a .050" chain 24 dollar
