stihl saws
You can always justify another saw.
- 3:30 AM
- Jan 18, 2016
- Virginia
Submerge and leave?Soak your line in a pail of water to keep it fresh and flexable so it doesn't break .
I think so too. The weight hangs on the harness and all u do is swing it side to side.I think with the harness these beasts are easier to handle than a smaller trimmer without a harness for extended periods.
How often does it need a soak?Yeah just let it soak overnight to 24 hrs.
Think Ill get some .155 Shakespeare Ugly today at Lowes and give it a ridego find you a power equipment dealer who supplies/handles oregon products and tell him you want a spool of .158 oregon flexiblade you will thank me later it can cut saplings and shrubs from 3/4 to 1 inch thick. but keep it away from vinyl siding and concrete it is some mean stuff and will cut stuff regular line has trouble with including crab grass.
Does it have a wire core or what? Do you have to wear kevlar to run it?go find you a power equipment dealer who supplies/handles oregon products and tell him you want a spool of .158 oregon flexiblade you will thank me later it can cut saplings and shrubs from 3/4 to 1 inch thick. but keep it away from vinyl siding and concrete it is some mean stuff and will cut stuff regular line has trouble with including crab grass.
Bet thats who makes the Stihl Durocut precut pieces. Looks like that
I wish that my blade still looked like that. It is almost filed away from so much use. I have a lot of respect for my FS 85 with this type of blade on it. It has cut almost 2 miles of trail through alder and young poplar brush and never has given a hint of fail. Just rev it up and swing through any tree or brush up to 3". Clearing the brush that was just cut while harnessed in a trimmer is another matter though!This is the style blade that works best for clearing trees. Also NEVER use regular circular saw blades as they are not meant for the rpm and abuse these clearing saws give out. They will shatter and you can get shrapnel everywhere View attachment 31543
That thing is awesome. My big question is, how fast can you drop it from the harness and run if you hit a bees nest?
I tried to tell you. Sometimes you just have to drop it. Lol. I've been into four nests this summer.Yall jinx me!! The yellowjackets tore me up this morning!!! Lol!! They were stuck to me head to toe! I was running with the brushcutter but unclipped it and dropped it and was still running and stripping!!!!
Man that was no fun!! These dang stings have itched for a few days nowI had the same thing happen about a month ago. I ran down the hill without unhooking the brush cutter. I was lucky and only got nailed twice.
