tallfarmboy
Jack of All Trades... Master of None...
I'm working on porting a closed port Husqvarna 350 that is getting a 353 piston... Anyway, the 353 piston that I got from Farmertec has 2 rings with pins spaced on the intake side... The 350 piston had a single ring with the pin directly in the center on the intake side... I plan on really blending these transfers toward the intake side, but it will expose the ring ends... If I reverse this 2 ring piston, it should work just fine on the exhaust side. Any input from y'all? Am I crazy? Can the piston locating pins be on the exhaust side?
Thanks!
TFB
Thanks!
TFB
