TPA1
OPE Member
When assembling case halves, I see that many people use a heat gun or oven to heat the case and they will put the crank in the freezer to reduce the fit for ease of assembly.
I want to try to keep the entire process on my bench so I will not have to walk to oven, freezer, etc... since my oven and freezer are in the house and not in my shop.
I have a heat gun for the cases, but I want to try the canned computer duster spray to freeze the crank, that way it will be ready at my bench without the need for a freezer, plus the spray can has the potential to get the shaft way colder than the freezer will.
So my question is, has anyone tried it before? You turn the can upside down so it will spray the liquid out and cryogenically freeze the shaft. Is there too much material in the shaft for the spray to adequately remove the heat?
