Scott chandler
- 11:09 PM
- Jan 1, 2018
- North Carolina Advance
394 to 395 conversion but with a new 395 carb and intake installed. Looks exactly like a 395 now with p/c and intake and when trying to adjust carb low screw didn't make much difference in adjusting and saw wouldn't hum would run idle just wouldn't clear up. Vac test good new seals so while troubleshooting more - when i took air filter and top off it will scream and run fine - adjusted with filter off just wont run with air filter on. It's an after market filter and everything lines up as far as filter and intake. I have ordered an Oem filter to try but don't know that it will fix problem. Acts like it is starving for air and can't adjust it out. New filter looks good too fits well. In beginning thought it was just extra oil i lubed everything up with but I've run it enough now that's it's cleared up. Adjusting carb just didn't do like it was supposed to. Not sure what to think - would changing over to high top style top and filter be better if new filter won't work ? Any suggestions or thoughts appreciated
