Sprinter
I have an older 562 from week 8 2012. Still has the 44B carb and has not been software updated.
Hot start has not been a problem probably because I work Mostly in the spring & fall. But as heat problems seem to be a big issue I've been worried about longevity!
Now to the good stuff!
So here's what I've done about it.
1) muffler mod - (@HolmenTree)
2) top cover vent - (@afleetcommand)
3) added insulating tape to partition under top cover.
4) opened top cover vent & removed air nozzle.
I understand that this last item will be of concern. I did try the carb vent with the air nozzle in and found positive pressure. Possibly, even a bit of intake boost. But, at the moment I am more interested in heat than power! So I'm going without air injection, in favor of lower intake temp and more cooling airflow over the cylinder. It should be noted that items #3 & 4 are easily reversible.
This afternoon, went to the wood pile and cut a couple dozen cookies, maybe more.
With my Fluke IR temp sensor I got the following readings from the top cover around the partition.
Temp above ambient
Front: 107F +25F
Rear : 87F +5F
Ambient: 82F
As a side note, I got an autotune print out at 10 hours that showed a Max. carb temp of 117F at 10 hours, witch was normal. Low start temp was 33F while average was 73F at start.
Of coarse, these are not head or carb temps but they should be relative. It's amazing the the carb temp was only 5 deg more than ambient. I wish I had temps from before as I believe those little bits of insulating tape (1" x 4") may have made the big difference.
(edit) Just found temps from a previous run without the air inject delete.
Temp above ambient
Front: 97F +40F
Rear: 67F +10F
Ambient: 57F
Different set of numbers but makes more sense when you look at them as difference above ambient. Hope this makes sense!
Thanks for your patience, Fred
Temp above ambient
Front: 107F +25F
Rear : 87F +5F
Ambient: 82F
Temp above ambient
Front: 97F +40F
Rear: 67F +10F
Ambient: 57F
