- 1:26 PM
- Jun 5, 2016
- Northwoods of Wisconsin
When I finished machining the base on a 353 I could not remove the mandrel, it was stuck hard. Finally after some persuasion with a plastic tipped hammer did it come off. Turned out the odd shaped bump out in the lower transfers had caved inwards on both sides. After some reflection I decided that I didn't quite know what was going on, but if the inside moved it had to take the outside with it and that would spell a leak.
In the end I bagged this one not trusting it to be of any use of any kind. Ordering a new OEMu 346xp ne cylinder kit seemed to be the order of the day
Highlighted and pointing to afflicted area
