Evansaw Pinnacle OPE Member Local time 9:49 AM User ID 4633 Joined Nov 20, 2017 Messages 876 Reaction score 3,524 Location Greece Aug 8, 2021 #1 Hi all I m converting a 25"rollo es 3003 from 3/8 to 404 Does someone knows the correct drive links for 404?
D DND 9000 Pinnacle OPE Member Local time 8:49 AM User ID 800 Joined Feb 6, 2016 Messages 728 Reaction score 1,621 Location Germany Aug 8, 2021 #2 You have 84 drive links now with the 25" 3/8 setup now? If yes, with the .404 setup it should be 77 drive links.
Evansaw Pinnacle OPE Member Local time 9:49 AM User ID 4633 Joined Nov 20, 2017 Messages 876 Reaction score 3,524 Location Greece Aug 8, 2021 #3 DND 9000 said: You have 84 drive links now with the 25" 3/8 setup now? If yes, with the .404 setup it should be 77 drive links. Click to expand... Thanks for that. Yes it's 84dl 3/8 1.6
Maintenance Chief Disrupting the peace with an old chainsaw Local time 2:49 AM User ID 11378 Joined Jan 4, 2020 Messages 3,791 Reaction score 11,977 Location South Carolina Aug 8, 2021 #4 77 for 7 pin rim sprocket, 78DL if you want to run an 8 pin, like say an 066 stihl.
Evansaw Pinnacle OPE Member Local time 9:49 AM User ID 4633 Joined Nov 20, 2017 Messages 876 Reaction score 3,524 Location Greece Aug 8, 2021 #5 Maintenance Chief said: 77 for 7 pin rim sprocket, 78DL if you want to run an 8 pin, like say an 066 stihl.View attachment 304877 Click to expand... 78 then cause i ll run an 8pin on my 661
Maintenance Chief Disrupting the peace with an old chainsaw Local time 2:49 AM User ID 11378 Joined Jan 4, 2020 Messages 3,791 Reaction score 11,977 Location South Carolina Aug 8, 2021 #6 I found I can sneak the 77 on if I pop the rim off the drum ,but I'd rather be lazy.
