Just what I have observed. Not saying it's fact...
- Oregon chains been slower in my other tests vs stihl as well. See attached. Yes I know no stihl RSL
- Limited data, But Square has been faster for me in pine and red oak then Round. While round has been faster in maple and ash. Then you add in factors like full comp, semi skip, full skip, power band of the saw, sprocket size. Gives me a headache!
- Stihl 404 RSL - doesn't exist. You'd have to cut a round chain. Which Tree Monkey did for the big oak cant. 36" 404 RS vs 36" 404 "RSL" RS cut square on his silvey. IIRC It was something like RS 41.5 seconds RSL like 40.3...it was faster, not by a lot. But it also depends on angles you choose on the square grinder. And then one might think, is it fair that you didn't round grind the RS...so both have been ground on a grinder? Because I haven't found any round grounded angle to be factory RS...and those apparently can't be duplicated. Gives me a headache! Lol
- I have observed the RS rolls to be super super consistent. YMMV and not so much on stihl's square cut chain. Sometimes fast sometimes slow.
- also one thing with oregon is the chains I've used so far all have given me slow times on the first cut and then the 2nd and or 3rd got faster. One thing I noticed with all the oregon I've had so far is that the drive links have a grey? coating on them...they have a finish of some sort. I'm thinking maybe that is causing friction on the first cuts and as it wears off = less friction. I stopped using oregon chain for my tests because I couldn't get super close consistent times like I can with Stihl RS. The Stihl chain has no visible coating on the drive links.
