Thumper88
- 1:58 PM
- Feb 28, 2020
- Harriman, TN
Located in Knoxville and you’ll need to tow it or haul it. Truck weighs approximately 11k lbs. clean Tennessee title in my name.
$1500 obo or trades listed below
International Harvester S1954 truck, DT466B inline 6 engine, hydro boost hydraulic brakes. Truck will need to be towed. All 6 injectors have been rebuilt. Had a stuck injector, so pulled them and had them redone. They are in the injector holes, need to be torqued down and the lines reinstalled. I’ll do it if I have time. Power steering pump has new seals installed, needs to be reinstalled on the engine. New rotor on the rear passenger side, I have the other 3 rotors to install. Truck is in decent shape, had a white oak bed installed this summer, 15’ long, 8 feet wide. 99k miles, 9000 hours. It has a 5 speed manual with a 2 speed rear end, rearend shifter isn’t hooked up and it’s currently in low side. I have a clean title in my name. Will trade for running and driving work truck or van, chainsaws, logging or tree work stuff, square grinder, whatcha got? I bought this as a wood hauler project. Drove it some in the summer, started working on it to fix the various TLC stuff and just do not have time.
