FOUND IT 12mm 044 crank, Piston and pin
NateSaw
5:13 AM
Maryland, USA
For Eric's 10mm 044. As long as I can use the 10mm jug, I'll need a 12mm crank, Piston, and pin. I'll shave the rod to fit the case. Jugs already ported and running nice. I just don't trust the rod bearing. I have a new 12mm pin bearing already. I want oem only, used good is great! 20230429_154140.jpg
