Dustin4185
- 12:45 AM
- Oct 25, 2016
- East TN
I was running the 045 AV I got a while back and it just died mid cut like a fuel supply issue. Pulled it apart and the piston and cylinder look good, 160 psi compression, passed vac/pressure test, and I have fire. The fuel line is SOFT and filter looks ok but I'm going to change it.
Is this fuel line available still?
How do I remove this one AV mount to get the fuel tank off? It has flats for a wrench, but dont want to screw something up!
I also plan on rebuilding the carb since it seems like a fuel problem to me.
Thanks
Thanks
