sherlock349
Active OPE Member
- 9:50 PM
- Jan 6, 2019
- Sussex United Kingdom
I am rebuilding an 038, ( I have rebuilt several 028,s and 038’s in the past) the crankcase I am using is in good condition and cleaned up well, I have fitted a new Stihl cylinder and piston kit Number 11190201202, I tested for leaks and all is okay. I have then fitted the coil and flywheel and pull start. The saw is extremely difficult to pull over with a plug fitted. No plug and it’s fine. I have used an aftermarket base gasket, is it possible that this has raised the compression causing the problem. It pulls over fine with out a spark plug. If a fully assemble I am confident I wont be able to pull it enough to start it. Any thoughts appreciated.
