- 11:42 PM
- Mar 13, 2023
- Maryland, USA
Bear with me as I share my notes. This thing has the hyway 44.7mm top end, an oem wt426b (new). Custom baffled muffler cover. Fire away fellas. I could use some help here. Any and all questions welcomed! It runs, and for a seemingly narrow rpm band, with quite the gusto. I had it pig rich to the point of pudding fuel in the case, and when I picked it up, it would stall. I've been approaching "leaner is meaner" carefully. I have the low side leaned out enough that it doesn't stall when I pick it up. The high is set to 4 stroke at 14k. 9500rpm in the cut seems ideal. Running a 20" bar (17.5 usable with long dogs) and an Oregon 22lpx081g chain (. 325 .063 with a 7t sprocket). I'm in the mid Atlantic region and it's mostly hard wood out here. Anyway, it cuts. But it seems to lack torque. A loose grip is dangerous, but I have to relax and let the weight of the saw determine cut pressure. If I dog in and pry, it just bogs and slips the clutch. Carb adjustment seems to be very narrow as far as what works best. What'd I do wrong fellas? Everything?
Also, I have the ducati coil. Fwiw.
