- 8:47 AM
- Mar 13, 2023
- Maryland, USA
That looks cool Nate.@drf256 said make it breathe... View attachment 372643
Thanks man. Left over mack truck grille mesh. Forgot I had it!That looks cool Nate.
No doubt! That's why she's all lopsided now. Thing can chuck some chips now. I about buried my feet making test cuts after work.Maybe opening up that side will keep the air filter from getting infested with chips so quickly. I don't know what is is about 0 series Stihls but it seems they have a snorkel to the chain cover.
Oh... I also put some of that mesh in the stow pocket for the winter mode panel. I'll never run winter mode. That may be the snorkel. Time will tell.No doubt! That's why she's all lopsided now. Thing can chuck some chips now. I about buried my feet making test cuts after work.
After 2 full work days of pretty nasty clearing... 1st picture shows how dirty this site made the saw... Next two, the airfilter. I didn't clean it once. Also you can see how I attached the cover latch tab to the filter to update it to fit. So far this airbox mod is tits. Sounds good, keeps clean. I recommend similar to anyone with the 0 series. Thanks again @drf256 for the filter, and ported p&c! It's breaking in nicely. Sounds balanced. And even with my leaky muffler cover, it puffs REAL hard at the exit.Maybe opening up that side will keep the air filter from getting infested with chips so quickly. I don't know what is is about 0 series Stihls but it seems they have a snorkel to the chain cover.
What's the difference between the 038 mag and a 380/381?I'm still looking for an 038 magnum piston and cylinder... If any of you guys know anyone...
Couldn't tell you. I know the mag is 52mm. The bolt spacing and bore is different going from av to mag. But if Stihl followed what they did with the 026/260 lineage....What's the difference.between the 038 mag and a 380/381?
Two totally different saws.What's the difference between the 038 mag and a 380/381?
The next one might be worse. China parts are never going to be like oem.Anyhow Rich, seems oem is relative unobtanium. I'm going hyway. I just need hl supply to get back to me about swapping out the one they sent with massive casting voids in the squish... View attachment 374245
I imagine I need to work the squish anyway. And yes, no doubt it's a dice roll wit da Chineseum.The next one might be worse. China parts are never going to be like oem.
Run it if the ports and plating are good.
Right... I'm more geared towards the bore diameter, the bolt pattern and the base to squishband measurement(s). I'll have to see if the Stihl guys in town have the specs/bolt patterns for the 038mag and the MS380.Two totally different saws.
380 has a much different pattern.Right... I'm more geared towards the bore diameter, the bolt pattern and the base to squishband measurement(s). I'll have to see if the Stihl guys in town have the specs/bolt patterns for the 038mag and the MS380.
