old_sir_henry
- 1:37 PM
- Nov 9, 2018
That's cool and hot at the same time!Home-made sticker for the 8700's starter cover:
Far from being perfect but acceptable. Some bubbles in the transparent coating.
That's awesome! How do you do that?Home-made sticker for the 8700's starter cover:
Cool thing is: The surface becomes non sticky and impervious and you can bend it even more
than the original and it won't crack:
Check and see if the flywheels and magnets index at the same spot relative to the coil.Maybe I can post this in the proper place this time.
I have a parts saw 5105 with heated handles. It has the White coil on it.
If I want to install these heated handles on my 5105 with a black coil and Easy Start, do I have to bring over the White coil with the flywheel, or just the flywheel alone, and change the starter pawls?
Thx!
A machine shop could broach a new keyway and drill and tap the case. Might not be cheap.
Shall I ask my German Dolmar dealer?Anybody know where I can get an air filter cover and engine cowl NOS in the gray color for the 64/73/79 series. I had a set and tried to dye them, let’s say I didn’t achieve the desired results the first time. Thanks. Not on much lately so I may not respond quickly.
