Wheelhorse 310 8
5155
7:59 PM
pa
Anyone know the name of that belled hose that runs from the back of air box into the crank case? Crank case vent or PCV maybe?
Mine is on crack and needs fired lol.
5155
7:59 PM
pa
Dealer said, no longer available.
KYsawman
7:59 PM
Gone Fishing
Do you have a part number or pictures of said hose, could match something up to make it work. Might hit eBay for a chance of NOS one.
FergusonTO35
7:59 PM
Boonesborough, KY
What kind of engine is it? Napa should have rolls of emissions hose that will work. You may have to heat it up to stretch the ends to fit.
5155
7:59 PM
pa
Good idea, I have a friendly napa store local here.
Another I thought, Use a short length of larger hose as the bell, glued or clamped.
It's on back burner for now as I wait for fuel pump.
Cant find anything about needed pressure but the thing only dribbles when I crank the starter. And it had fuel starving symptoms.
Dealer wants too much for pump, so here I go again AM.
Electric low volume pump is an option too.
Yes I searched that WH forum. I suck at that.
edit Its a Kohler 10 hp
5155
7:59 PM
pa
Found a PN and drawing on parts tree.
toro Part# KH10309
They name it "hose".
N/A
You guys will make a parts hunter of me yet.
