- 6:19 AM
- Apr 28, 2016
- Croatia
Mine were always hard to start, I even have to play with the choke to get them running.On a slightly different topic, but same 105 saw, fuel priming. From cold it needs around 6-8 pulls to prime the carb with fuel, then fires up on choke, then runs normally. Is this normal? The 153 needs only a couple of pulls to prime, as do the Homelites. I've been wondering if this indicates an air leak in the 105 carb, or whether it would benefit from adding a priming bulb? It only needs the priming pulls if it has been left for a few days, not once it has started that day, even if it is cold again.
Once warm they'll start one or two pulls.
I always assumed they simply have a weak pulse to pump the fuel.
I wouldn't be all too concerned about the starting behaviour of a Sachs-Dolmar 105/108
